fork oil level
Old 10-16-2018, 11:50 AM
Ronnie Stipe's Avatar
Ronnie Stipe
Ronnie Stipe is offline
Stage IV
Default fork oil level
I got a 2014 xl1200c. I’m replacing the stock fork springs with progressive stock length springs. The instructions say it will use less oil than the o.e. springs but don’t say how much to use just gives a min. I don’t want to blow out the seals or have the level too low. All help would be appreciated!!!!
Old 10-16-2018, 01:25 PM
harley506d's Avatar
harley506d
harley506d is offline
See if you can find the oil level measurement from the top, that won't change.
Old 10-16-2018, 07:49 PM
Grey_Beard's Avatar
Grey_Beard
Grey_Beard is offline
When in doubt call their tech support. They'll be glad to help with your concerns.
Old 10-17-2018, 12:10 AM
Ronnie Stipe
Stage IV
Thank You both for the advice
Old 10-17-2018, 08:15 AM
Kenny94945's Avatar
Kenny94945
Kenny94945 is offline
Yes best answer is to call tech support.
Just maybe the instructions say that because the springs are physically thicker displacing the
amount of oil....when set to the OEM oil level (not volume/ amount/ ounces) measurement spec.
Buying an oil level tool (fairly inexpensive) I recall near $25. is a tool you'll have for a lifetime.
Have fun.
Old 10-17-2018, 05:28 PM
normannewguy's Avatar
normannewguy
normannewguy is offline
Can you let us know what the response was?
Old 10-18-2018, 12:49 AM
Ronnie Stipe
Stage IV
Default reply from prog.
the guy from support said 5.5 in from the top of tube. the tube must be collapsed fully.
Old 10-18-2018, 02:37 AM
harley506d's Avatar
harley506d
Easier to do with the forks off, so you can get the level centered.
And, if off, you can empty them easier and then flush with some cleaning fluid until it comes out clean.
You can make your own level syringe real cheap to save a few $
Old 10-18-2018, 10:46 AM
normannewguy
Fun , looks like you get take fork off unless you can maybe jack up back end till forks are level, then fill.
1forrest1
04-30-2013 10:44 AM
HeelDragger
06-21-2012 02:11 PM
dynalo
10-19-2010 11:52 AM
ubreal
01-22-2010 10:16 PM
carpet dude
11-05-2007 09:10 AM
Quick Reply: fork oil level
