charcoal canister disconnect
hey everyone , i have a 96 heritage, i want to install a shotgun shock set up, but the compresser goes where the charcoal canister is, ive been told to take it out and toss it,the way it is now theres 2 lines going in,for vapor and 1 coming out - the one coming out is dissconnected and the hose is plugged, the 2 going in are connected as normal. my question is , if i toss it and zip tie the 2 hoses going in (so they wont flap around , not to plug them) will it effect how it runs, will i be able to smell gas, as my mechanic friend thinks?
Received 4,317 Likes
hey everyone , i have a 96 heritage, i want to install a shotgun shock set up, but the compressor goes where the charcoal canister is, ive been told to take it out and toss it,the way it is now theres 2 lines going in,for vapor and 1 coming out - the one coming out is disconnected and the hose is plugged, the 2 going in are connected as normal. my question is , if i toss it and zip tie the 2 hoses going in (so they wont flap around , not to plug them) will it effect how it runs, will i be able to smell gas, as my mechanic friend thinks?
If you're running a carb just take it and all related hoses off your bike.
All you need is a vent line from your tank down to your swing arm.
Make damn sure you don't pinch that hose.
You can get a good idea of what parts are involved by checking a parts website, or better still if you have the FSM. However does your bike have to pass any local inspection where they will check for that canister? Would be a bit unfortunate if you have to put it all back on!
Can't answer what hoops the OP has to jump through to register the bike in Cali, but the OEM shocks on a '96 Softail are adjustable for preload, but not for ride height (shock length).
splattttttt (10-20-2018)
I would not modify it but if you do, get the one way resistance check valve that goes in the line. If you just run a hose, the surge of raw liquid fuel will be able to go into hose when you brake. The way is is designed in the non canaster states is there is a vent in only, in the tank fuel cap. Normal running puts a vacuum on tank and since vent hose is a air lock, raw fuel does not dump into it. Sitting and off, any heat build up pressure pushes only air/fuel air fumes from down vent. That valve must be clamped verticle.
Here in VA, a state inspection could reject a change like this since it is a $10,000 Federal fine for them letting it pass.
