Shifting issues w/ 2019 Street Bob
Howdy folks,
I just bought a 2019 FXBB Street Bob and have put about 280 miles on it. Since day one I've had repeated problem shifting from 1st to 2nd after the bike gets "really" warmed up. I say "really" warmed up meaning it doesn't happen frequently until after I've ridden the thing for more than about an hour or so. When the bike is cold it shifts perfect, like butter. Towards the end of my rides it starts getting stuck in neutral when attempting to shift from first to second. Even if I pull in the clutch and attempt to shift up again into second... I'll hear/feel a tactile "clunk"... but it stays in neutral. I can repeat this multiple times and it just won't go into second. I literally have to pull to the side of the road, slow down to 10mph or less, downshift into first, then attempt shifting into 2nd again. There are no grinding of gears when this happens. It just seems like the arm clunks up into second... and then fall back down into neutral.
The first few times I thought it was me as this is my first bike with mid-controls. Prior to this bike I put about 35,000 miles on a 2012 FXDW Wide Glide with forward controls. I never had a single shifting issue with that bike. It was perfect every time. This new bike has been nothing but trouble trying to get it into 2nd gear. I brought it to the H-D dealership and even though I told them they need to ride it a good 20+ miles for it to start happening they told me two different techs rode it at least 5-10 miles and shifted the bike from 1st to 2nd at least 30 times each with no issue. They said they couldn't replicate the problem and the bike is a "representation of the product" meaning it performs as designed, and they sent me on my way.
I've adjusted the clutch 3 times with no improvement. Twice I did a standard 3/4 counter-clockwise back-off prior to torqueing the jam nut. Recently I only backed it off 1/2 a turn hoping to maximize clutch disengagement. Still no improvement. I'm bringing it into another dealership to see if they can replicate the issue. Anybody have any thoughts on this?
Observed scratches
One other comment/observation. I noticed these scratches in the clutch pack at about 240 miles. This was when making the third clutch adjustment with the rod backed-out 1/2 turn instead of 3/4. Not sure if this is normal wear for a new bike or cause for alarm. The design is different than my Dyna.
Campy Roadie (11-04-2018)
I think those scratches are where the casting was deburred at the factory. Not 100% since have not had this new design apart. However, I guess that is the SE slip and assist clutch. So be sure you are following the 2019 service manual.
Just looking at fish after finially finding one, appears something has broken if those two parts are in contact.
I can understand your motivation to fix it since what they did and the fact that it depends on certain conditions to actually act up. The clutch is mechanical enough that this should not be occurring.
If you adjust, be sure you screw in the adjuster till all play is gone and then in a few more turns pushing in clutch and deburring fine threads. Do not back off cable slack all the way. Then find no play at clutch and use lever to verify this. Lever and screw in at clutch and you will fill what I am saying. Then back off 1/2 turn if cold or 3/4 if primary is a little warm. Now, double check by bumping bike in gear to move motor and transmission.. This will reposition throw out bearing. Now recheck back off. If the same, you will know throw out bearing is ok.
Now, snug locknut and set cable free play at minimum checking at both locks of bars. Make sure primary has only proper amount of formula+ oil (up to bottom of diaphragm spring). Got to look way down in for that. That oil should also be in transmission. Others work, but none work as good thru out the various temperatures from cold to hot.
Caleb Owen (01-17-2020)
Give the dealer some slack "you can't fix what ain't broken". Until they can replicate the problem what do you expect them to do. I guess most HD critics figure that the dealerships just leave the bike in the corner, don't ride it and then tell the customer they can't replicate the issue.
Thanks
