Where to store new bike?
Received 2,858 Likes
No need to remove the battery but do put it on Battery Tender. If you don't have a bike cover a blanket or old sheet over it just to keep the dust off. That way, as thumper has said, it is ready to go if the Temp goes up. If the Bike is going to set for more than a week at a time then start it up and let it run till the motor gets up too operating Temp ( helps to keep the moisture out of the oil ).
KenK
KenK
Cold won't hurt a thing. I wash my bikes twice a year. When I get it out or put it away. Tender as mentioned is a necessity. I leave the battery in the bike. Never have taken one out. Jack it up some if you wish to take pressure off the suspension? Main thing is to treat the gas. I won't use Stabil, Marine or original. I've had too many issues with both. (to each his own) I use Sea Foam to store and use half can per bike in all 3 bikes and never an issue in the spring.
Go for a short ride if I can or run the bike till it warms up to circulate whatever you use in the gas. Either is good. I start my bikes to get rid of moisture, never a problem.
TwiZted Biker (12-08-2018)
