Suspected torque error in FSM
Old 12-09-2018, 01:47 PM
Stickman53's Avatar
Stickman53
Stickman53 is offline
Default Suspected torque error in FSM
Just bought a 2019 Road Glide. Installed 13 inch shocks on the rear to replace the 12 inchers.....the 2019 service manual calls out a torque of 63-70 Ft pounds for the attachment bolts. If I recall correctly the torque for these bolts on my 2009 was 35-40 Ft lb. It's the same P/N bolts on the 2019 as the 2009. So I'm thinking this torque value is too high. So I split the difference and torqued them to 50 Ft lbs.
Now I'm wondering how many other mistakes are in the freaking manual.....geez eh....
Old 12-09-2018, 02:06 PM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
No magic involved, it probably will not fall out of the air.
Bolt Torq guide
http://www.repairengineering.com/bolt-torque-chart.html
The following 2 users liked this post by Kingglide549:
hbsoldier3 (12-10-2018), memphisharley (12-09-2018)
Old 12-09-2018, 02:09 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is online now
Received 29,199 Likes on 11,126 Posts
Or maybe the 2009 values were wrong.
IMHO 35 ft-lbs seems low for shock mount bolts.
Old 12-09-2018, 02:57 PM
Dynamick's Avatar
Dynamick
Dynamick is offline
Not a Moderator!
Received 6,619 Likes on 3,209 Posts
My '13 FSM specifies 35-40 ft-lbs as well
Old 12-09-2018, 03:26 PM
dribble's Avatar
dribble
dribble is offline
How do you know it's an error and not just an updated torque spec? These are two completely different bikes.
Old 12-09-2018, 04:05 PM
Stickman53's Avatar
Stickman53
Agree they're different bikes BUT the P/N of the subject bolt is the same (3607), so why the torque increase?
Old 12-09-2018, 04:06 PM
TriGeezer's Avatar
TriGeezer
The torque spec is what is required for the application, not the bolt.
Old 12-09-2018, 04:42 PM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,628 Likes on 1,176 Posts
35-40 in the 2015 touring FSM.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 12-09-2018, 08:24 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,231 Likes on 1,809 Posts
Touring FSM
2016 35-40
2017 63-70
2018 63-70
Old 12-09-2018, 11:10 PM
tnriverluver's Avatar
tnriverluver
tnriverluver is offline
Touring FSM
2016 35-40
2017 63-70
2018 63-70
Hmmm I need to check SM that just arrived last week. Think I only tightened mine to 40.
Quick Reply: Suspected torque error in FSM
