Stage II with Red Shift 468
2017 Road Glide Ultra
Zipper's Red Shift 468 cam, Arlen Ness Big Sucker A/C, Fullsac exhaust header, CVO mufflers with Fullsac 2" power cores, ThunderMax tuner. Immediately noticed crisp throttle response, lopey idle. I don't know what the torque is but it pulls hard down low. The exhaust is not loud but it barks under heavy throttle. The cam is working good with the ThunderMax!
I bought the Tmax from Cycle Solutions, they had the best price that I found. There are only about four base maps in the software with this cam so I used one that had the stock FL pipe with cat removed. After riding it for about 50 miles I could see where the Tmax was making fuel adjustments to the base map. I just finished this two weeks ago and it's been cold, so not a lot of riding yet. So far I am happy with the results.
You might want to get in touch with Zippers & see if they can give you a better base map, the Tmax adjusts the AFR , but can't change the timing charts. A better base map could chow some overall improvements, both in power & driveability. I have a Tmax also & there were very few maps for the M8 since it is so new, I haven't talked to them yet since I'm not running their cam, but they are the experts.
Sounds like a good plan, mine got better with more time & learning, I was only getting 37-39 MPG out of the box, it's up about 5-6 from learned fueling, but I'm thinking that it may be leaving some on the table as far as the timing is concerned. There aren't many tuners that will actually tune with the Tmax, but I've seen a few that have been tuned & gained about 4-5 HP TQ.
