114CI setup
Old 01-07-2019, 02:10 PM
AzRoute66's Avatar
AzRoute66
AzRoute66 is offline
Default 114CI setup
new take off from a 2018 softail ... 114" complete setup ... heads, cylinders, pistons ... removed at less than 100 miles ... new take off's ... $650
Old 01-08-2019, 11:52 PM
Silent_Sapper's Avatar
Silent_Sapper
Silent_Sapper is offline
What is included? Just what’s pictured or complete setup?
Old 01-09-2019, 12:41 AM
AzRoute66's Avatar
AzRoute66
yes,...pictured items ...
Old 02-15-2019, 09:25 AM
AzRoute66's Avatar
AzRoute66
upgrade for M8 107" to 114" upgrade kit ...
Old 02-15-2019, 02:56 PM
yobtaf103's Avatar
yobtaf103
yobtaf103 is offline
Not quite correct ,as a different stroke, so pistons will not work
but your 114 cyl can be taken out to 120 with matched pistons, as a nice gain for a 107 guy
Old 02-15-2019, 05:39 PM
AzRoute66's Avatar
AzRoute66
appreciate the mention of stroke ... didnt know there was a difference...you are correct ... 4 3/8" versus 4 1/2" ... 114" having the longer stroke ... so my question is ... l believe it should still work ... 107 has slighly shorter stroke, so it will benefit from the larger pistons and cylinders... the small difference in stroke should equate to possibly a 113" then versus 114"
Old 02-15-2019, 06:17 PM
DTTJGlide's Avatar
DTTJGlide
DTTJGlide is offline
NO, you would end up with a 111 with only about 9.25 compression ratio, it would run worse than stock, the pistons & cylinders are the only parts that are any different than a 107, so you basically have some cylinders that are worth something & a set of take off heads that are the same as the ones on a 107.
Old 02-15-2019, 08:46 PM
AzRoute66's Avatar
AzRoute66
not to turn the classifieds in a discussion forum .. but, you are correct to estimate it would end up being a 111 with lower compression due to shorter stroke ... this would be the perfect time to clean up a set of heads to flow better and mill the heads to make up the short fall of compression thus bringing you back to 114" with a good compression to run a strong cam ...
Old 02-16-2019, 01:32 PM
DTTJGlide's Avatar
DTTJGlide
I didn't estimate, I ran the figures, I just didn't want somebody to think he was getting a big upgrade because he didn't have the knowledge, your suggestion of redoing the heads would cost more than a simple stage 3 & if you cut things down that much nothing would line up. Advertise your parts for what they are, a set of take off heads & 114 cylinders, not a 114CI setup.
Old 02-16-2019, 01:59 PM
AzRoute66's Avatar
AzRoute66
for sure ,.... sounds like these are just that ... l good set of takeoff heads and a good set of cylinders... not a 114CI setup...........
Bill wallace
Shovelhead
12-30-2018 06:09 PM
SinglePipedSG
08-11-2018 03:59 PM
Ironworker69
EVO
01-31-2018 12:43 PM
Quick Reply: 114CI setup
