Derby Cover Bolts
Received 5,374 Likes
The following 4 users liked this post by bagga:
I can't help with the size as I've never had the need to replace them however whether or not you go with hex or torx, always use the correct bit and use a speed handle to remove and install them.
The speed handle allows pressure to be put on the bolt/screw while being able to control how much torque is being applied.
I always use a 1/2" with a 3/8" adapter with bit due to the bigger 1/2" drive allows for more control.
However since you can get both the 3/8" and 1/2" for under $18 they both should be in everyone's tool box that wrenches their own bike.
https://www.harborfreight.com/38-in-...dle-62700.html
https://www.harborfreight.com/1-2-ha...dle-95992.html
Death Valley Ultra (05-06-2021)
