117" - 110 heads - 263E cam compression requirement
As per usual it's winter and I'm stuck at work for 6 months and over thinking my spring engine mods.
The bike is a light and nimble FXSE with a 117" "stage 4" kit inclusive of the 110 heads, 259E, 58mm throttle, bigger injectors blah blah blah.
I want to get my heads done which includes 2.12 intake and wiz bang porting yada yada yada.
My compression is currently the stock 9.9-1
I can go 10.7-1 with the head work easy enough.
This was my plan until a few days ago.
I keep coming across these 11.5-1 compression 10cc dome pistons for my engine and then a set of new 263E cams popped up that I immediately dismissed until I started digging into them and it looks snotty.
So... is the 263E cam and 11.5-1 compression a winning combo or should I stay with 10.7-1 and the 259E cam.
I do everything with this bike. Quick runs to the gym or 10 hr long day rides. I barely ride 2 up and when I do she weighs 120 lbs including her 6" heels and shiny pants
When I tour it's basically a backpack strapped to a sissybar.
I ride all over my rpm range but find myself usually at 3000rpm no matter what I'm doing. I like to run it up to red line and giggle all the way with the current 9.9-1 259E configuration.
Hope that's enough information for informed responses!
I run a 116 ci Dyna (carbed 2000 FXDX) with a cr of 11.3 to 1 and a 625 SnS cam. Really don't have any issues with pinging and it seems to run just fine (about 16000 on this build). I don't have any problem putting some miles on it but would not want to get stuck in traffic with temps much above 90F. This bike will likely stay this way until the crank dies then either go to 117 or 113. (Tired of the 4 5/8 crank and 1200 gram piston weights) You can probably trim the domes some is you want to drop the CR some.. Get it down to say 11 to 1.
By the way@11.3:1@55*ivc, is not a fair comparison...
Max. You obviously know what your doing and can get away with a little higher dynamic compression... But putting 11.5:1 on a 53* ivc is pushing it for a novice. His tune would have to be so spot on and on a day's that it does hit 95-100*... Well he could be screwed... But what ever, it's not my bike and this ain't a pissing contest...
I guess you misread this.
"You can probably trim the domes some if you want to drop the CR some."
