Doubts in the air intake 114
Old 02-15-2019, 11:50 AM
Gead's Avatar
Gead
Gead is offline
Default Doubts in the air intake 114
the 2019 RKS models are coming with this hole closed, the 107 is open, what's the difference? ,
Old 02-15-2019, 12:56 PM
Gead's Avatar
Gead
Gead is offline
Old 02-15-2019, 01:01 PM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 8,516 Likes on 4,422 Posts
why they changed assuming 'just that' is a great question...wonder if they like the fact it concentrates the velocity of incoming air lower to swirl around the enclosure? seems the forward facing element getting the direct rush of air would be good, or maybe it is to keep the forward facing part of the AF from getting wetter and dirtier faster? digging deep on that but other than that, I got nuthin'...
Old 02-15-2019, 01:37 PM
OldMike's Avatar
OldMike
OldMike is offline
Received 1,837 Likes on 1,212 Posts
That's interesting, huh?
Old 02-15-2019, 01:38 PM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,458 Likes on 755 Posts
My guess is its merely a cost saving, not a performance advantage for the stock filter application. Gives folks more incentive to go stage I
Old 02-15-2019, 01:45 PM
Gead's Avatar
Gead
Gead is offline
I bought the kn 1717 and did not expect this hole closed! Is it a functional modification or should I open a hole?
Old 02-15-2019, 02:20 PM
mjwebb's Avatar
mjwebb
if you are leaving your engine stock just leave it as is..believe it or not they design and test these things and it works sufficiently for stock
Gead (02-15-2019)
Old 02-15-2019, 02:23 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,272 Likes on 11,143 Posts
But, the K&N filter is supposed to be a better breathing filter. Will it now be constrained by less air intake.
Old 02-15-2019, 02:35 PM
mjwebb's Avatar
mjwebb
my opinion is the OEM provides all the stock engine and tune requires..don't always need a stick of dynamite when an M80 will do the job just fine..but you could spend the money, it has advantages of being more reusable but I also contend it will allow more fine, gritty, sandy sediment pass through into the engine which is the enemy..in real world practical application does it matter much, probably not being enclosed..I also called K&N early on with my M8 and they said they recommend retuning if adding their OEM replacement along with freer flowing mufflers
Gead (02-15-2019)
Old 02-15-2019, 02:36 PM
Gead's Avatar
Gead
Gead is offline
I bought the kn1717 and V & H Eliminator 400 tips, I'm out of action now.
Quick Reply: Doubts in the air intake 114
