Picture of right side turn signal terminal
Old 02-16-2019, 06:00 PM
JasonA1's Avatar
JasonA1
JasonA1 is offline
Default Picture of right side turn signal terminal
hey I’m wiring in new turn signals and broke the block so I tool all the male pins out but forgot to take a photo of where they belong I have the service manual but it’s not helping the right side is dead still when I plug them in I did have to solder a few wires and put in new pins could this be the problem
This is the female side and the picture wires don’t corespond with the wiring diagram the green and orange are together but in the diagram there apart
Old 02-16-2019, 06:35 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,706 Likes on 1,343 Posts
What color are the wires on the other side of the plug?
Old 02-16-2019, 06:38 PM
JasonA1's Avatar
JasonA1
JasonA1 is offline
I need the male side and to see where they are plugged in so o can copy it as I have no idea
Old 02-16-2019, 06:43 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
In my experience, the manual is exact in the colors and position of the wires in the plug. And, in general, the colors match across the plug, as you can see in the schematic. And, some punctuation really helps readability, eh?
Old 02-16-2019, 06:47 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,742 Likes on 928 Posts
Take look at the other connector that the one in your hand mates up to and you should be able to match them up. Also your schemo shows where they should go, just look at the wire colors on the schemo and "follow them". The schemo should tell you what wire colors go to what ever turn signal or switch. Take it one at a time and you will get it.
You can always use a 12 volt test light or a meter to determine hot wires. YD
EDIT, looks like other beat me to it, what connector are you working on? 3a/b, 2a/b etc. Your schemo has them labelled. YD
Old 02-16-2019, 07:00 PM
JasonA1's Avatar
JasonA1
JasonA1 is offline
how do I check with a multimeter
Old 02-16-2019, 07:18 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
You would to better to use a test light but the procedure is the same either way.
Connect the ground lead to a ground and use the hot lead to find out which pin flickers when you have the turn signal on for each side.
Then just make sure the wires you fix line up with the wires you identified.
Old 02-16-2019, 07:20 PM
Yankee Dog's Avatar
Yankee Dog
Yeah! What he said!! And be careful, you have a turn signal self cancelling module that is sensitive to electrical shorts, so it can go to chit in a hurry. Be careful with touching wires with probes and such. YD
Old 02-16-2019, 07:35 PM
JasonA1's Avatar
JasonA1
JasonA1 is offline
cool thanks
Old 02-16-2019, 08:47 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
It looks like someone changed the running/turn signal light that's why you have a BE(blue) & V(violet) wires in connector 4B. That should also be why you have that BK(black) wire that is not used. The O(orange) wire should be in opposite the R(red) wire. Also check to see that connector 4A has a commoning tab 3 place installed. If it is missing, that could be why the green & orange wires were together.
Quick Reply: Picture of right side turn signal terminal
