Hello everyoneI have a 18 cvo with a zippers 468 bassani power duals and 2.0 fullsac cores would be worth it to change to change to 64mm throttle body and bigger injectors.
Have you had it dyno tuned? If not, that would be a better use of that kind of cash outlay. You might also consider the SE ported manifold for the stock throttle body. I would probably go that route with the 5.5 injectors.
You really only need to increase the throttle body size if you go big-bore. The injectors couldn't hurt, but I agree with $tonecold's recommendation. Dial in the tune.
What is the stock throttle body size on the 117 cvo
All of the factory M8 throttle bodies are the same, doesn't matter if its a 107, 114 or 117 (55mm). The SE replacement throttle body is 64 mm and comes with a new intake manifold. There is also a SE replacement intake manifold for the stock plastic one that you use your stock TB over again. I am not so sure porting a aftermarket (SE) manifold is worth it. We have tested a couple of them and not found any real change in performance with them over the none ported versions. These were the 64 mm units that we were testing on 117 and 120 engines.
If it's running well don't screw with it, going with a 64 & injectors means it will need a new tune= $1k spent for a couple of HP, the 468 is a TQ cam anyway just use the TQ.
