Fuel management system recommendations
I have decided to go with a local custom exhaust maker here in northern California but not sure which fuel management system to choose from. Looking for recommendations.
Bike = FLHCS Heritage Softail Classic 114ci
Exhaust = Fab28 2 into 1 for m8 motors
Just be aware that your warranty will be voided if you use anything other than the Harley Street Tuner. It may be voided using that exhaust anyway.
Also, doubtful if the street tuner would be able to tune to that exhaust systems requirements.
My first experience with tuning an ECM ever was using a Master Tune on my SE build. The 2003 Ultra basket case project I bought had SE 204 cams and Rinehart True Duals. I found a Master Tune blue box in the tour pack. I put a pretty radical build on a replacement engine and I bought the cable set $45, and downloaded the software into my laptop and chose a configuration close to my build and then uploaded it into the ECM. Easy. Although it was not an exact match, the tables ran pretty good but needed tweaking. I then learned how to record and tweak the tables doing road runs. It was intimidating at first, but you cannot screw up if you pay attention and follow directions. The first thing it does is prompt you to download and save the existing tables so you can always go back to the previous table you installed before, even back to the original map tables.
