Softail LowRider vs FXDLS
Opinions needed...
I'm trying to decide between a stock 2016 fxdls and a new fxlr (customization pending). Ive ridden both bikes and I'm torn between the two. What are people's opinions on this comparison? Not looking for a dyna vs softail debate. Just curious what the public consensus is. Both bikes can be had for around 15k, although the fxlr would involve quite a bit more in pricey mods. What do we think?
I have ridden them both and it's s a serious toss up. Really liked the smooth power delivery of the softail but the fxdls has dual discs and that TC rumble. The 110 gets super hot though. Generally felt like the softail handled better but the dyna is a better stock package. The fxdls is going to hold its value much better but the fxlr is an all around better ride. Idk. Its a hard decision.
I looked at the FXDLS really hard because I love the looks, but in the end it couldn't (IMHO) touch the ride and handling of the new Softail. Like you said as well, the 110 gets really hot, and you can feel it. Then again, I'm really partial to the M8.
Good luck with the decision, they are never easy!
The new Softail chassis is a big improvement over the Dyna. The M8 is smoother than a TC, and as others have said, the 110 gets very hot.
That being said, when i traded my M8 114 Breakout i could have had a new Softail Low Rider or the Low Rider S, i went with the Low Rider S. I have no regrets and still believe i made the right choice. The new bikes might be better, but the Low Rider S is raw and much more exciting to ride.
I looked at it as 'skipping a generation' when going from my '03 Dyna to the '19 Low Rider.
Better chassis design. Integral cooling in the head. Internal engine dampening. Cooler engine.
And, while the rubber mounting of the Dyna is very good and provides for an enjoyable ride, those elastomeric mounts degrade and can induce dangerous coupling between engine vibes and chassis dynamics - at least it did on my Dyna. Easy enough to fix with new motor mounts or adding a linkage system like True Track, but not cheap either.
Any softail owners have issues with the single disc brake on the fxlr? The dual discs on the fxdls are definitely a bonus, but i haven't had the opportunity to go out and thrash a fxlr yet so I can't really compare. Also, is there a compatible hub for the fxlr that can take a 2 disc setup?
IMHO, dual discs on these bikes are for show. A good single disc will stop as much as you'll ever need and is a good deal less unsprung weight. I was actually looking into removing a disc if I got a Dyna Lowrider, that's why I started looking more at the Super Glide and Wide Glides as well. I know my FXLR stops just great. Of coarse, I still remember Drum Brakes.
