Heat Shields Or no?
Heat Shields Or no?
Fellas,
Finally got around to taking my exhaust off and getting it ceramic coated. My question is putting the heat shields back on? Besides adding some bling? I am wondering if the really would feel that much heat off the pipes? I am thinking a nice clean set of black pipes might look best. THoughts?
I'd install it without shields to see how YOU like the result. It's your motorcycle after all and they are easy enough to reinstall.
BTW when I install exhaust systems I anti-seize all the threads. Dry threads leave room for moisture intrusion which causes corrosion. Anti-seize prevents twisting off exhaust studs.
