My new 62 Duo Glide
My new 62 Duo Glide
Ive wanted a pan for a while and Ive been watching them on ebay, certainly nothing in the local classifieds. A few people knew I wanted one and I was told about this one Sunday night that was available but not advertised. I looked at it yesterday and made the deal last night and brought it home this morning! 20 mins from my house. You just never know whats tucked away in the garage down the street.
I know its not 100% correct and for the most part know whats wrong but its an honest bike and the belly numbers match. The anti theft codes both start with an A on the frame and the gearbox. I have tons of pics so Ill add more later. I need to address some items, hasn't been on the road in 27 years but I did hear it run last night.
Feel free to pick it apart like my 66 was, it'll be an education.
Im super excited!
Im super excited!
The following 12 users liked this post by hellonewman:
62 Pan Shovel (10-02-2020),
Beast71 (04-01-2020),
DanDeleted (03-23-2020),
Gearhead88 (09-07-2020),
Harfar (10-15-2019),
and 7 others liked this post.
Received 4,895 Likes
Now I am jealous. I want a Duo Glide, and I want one with a tank shift. Hen's teeth and all of that, but they are out there. Had a guy offer me one at Oley last year, original tank shift bike that had been converted to foot shift. Was not ready to make the plunge, maybe next year. Congrats and good luck.
Thank you,
I was told it may have been a cop bike but looking inside the left tank I see no remains of tank shift bungs. Console has no neutral light, has a damper on the tree and the front brake cable tube looks too long but has been bent to go over the fender. Who knows? Not sure how I could ever find out. Original owner is dead and Im owner number 6.
Received 6,044 Likes
Here's what I know is wrong:
Obvious stuff like the chrome light and plate bracket (under the bracket full of lights). Lower light.
Chrome oil tank, chrome repop tool box, chrome oil lines I think and filter.
Popsicle pedal should be bicycle pedal, maybe a black kicker arm? Rear pegs wrong?
Foot boards, air cleaner cover is chrome not stainless and has no cleaning instructions. Other small chrome do-dads.
Wrong bags, guards, exhaust.
Chicken foot was an option.
Repop speedo, goofy wrap around the cables.
Regulator is on the wrong side and converted to 12V
CanadianRocky (10-20-2020)
Received 3,210 Likes
Is there a 2nd light of some sort below the rear fender?
Got my oil lines in correct finish from this guy https://www.denniscorso.com (think I mentioned him re: your Shovel build)
Yes on pedal, and black kicker arm. Passenger pegs and mounting brackets are incorrect.
Footboards and pads are 66; yours need to be the half moon. This guy has some nice repo stuff https://deluxehdrestorations.com I used his pads for my 49 EL. Hard to tell the differenence overall from OEM ones. Think I took some pics. I find them I'll post them.
Ok...yu got me. 1st time I've seen something like that.
Fortunately correct speedo for these years are more common than not (tho just checked the flea and there are none; over last 3 weeks i have seen 5 up for bid). The goofy plastic wrap around black cables was a popular dress up option.
Think I may have a 6-volt genny but not sure of correct application. Know its a model 58 something. Also have the right side regulator mount and Bosch regulator. I'll dig those out.
Know folks get hung up on the whole thing with points and condenser. That said you might check this guy out. Drop in electronic system and you cannot tell unless you pull the cover http://www.ebeyond2000.net/quickstart.html
Few other things I noticed after a quick look.....
Chrome swing arm and swing arm bolt
Tranny filler plug
Acron cap nut on fuel shut off valve + acorn cap nuts on lots of different areas
Grips
Rear brake pedal pad is 67 and later
Can't tell if rocker cover screws are 1/4" hex hd but should be
Exhaust clamps should be stainless (looks like they might be)
What the heck is the cable/tube running down the right side of the bike, travelling just above the horn and disappearing behingd the carb?
Think that the lack of a neutral light on the dash cover went with the tank shift models.
Looks like he chewed the heck out of the clips to secure the pushrod covers.
Your heads appear to match what Palmers states about casting and date codes on the heads. Should be some date code numbers for your cylinders as well.
Tranny filler plug
Grips
The following 2 users liked this post by johnjzjz:
RENARELLO (06-12-2020),
TwiZted Biker (04-20-2019)
Im good with that! In fact Ive been doing all of that in advance the last couple of years. Wainscotting in the hall, added a loft over a garage and working on a new staircase in a better location in the house. Its how I spend my weekends.
**Yes that light is bolted to a plate thats welded to the cross bar that connects the bag brackets at the bottom.
***Ill go with those this winter.
****put the 65 down boards on that came off my 66 and removed the pegs and brackets this afternoon
John Bordas has my 66 speedo for a restore, Ill see if he has one like it for the 62 otherwise Ill keep looking
Tranny filler plug
Grips
**** I have a spare arm in black, the chrome bolt bothers me and I will replace it as I did on my 66.
Wasnt sure about the trans plug, ordered a replacement fuel shutoff for now so I can ride but will get an original at some point
What grips should it have? Smooth like the 66?
Rocker cover screws are hex bolts.
**** its the I.V. line I used to run the bike without filling the tanks. Tanks need cleaning and the carb had just been rebuilt.
Tranny filler plug
Grips
