Vibration over 70mph 2013 Dyna
Having a vibration over 70 mph. Started about 6 months ago. Makes things blurry. Changed shocks( to Ohlin), replaced motor mounts front and rear-- Predator front and oem rear. Rebalanced both wheels All with no help. Actually a little more vibration. Nothing is touching frame. No noises. No wobble. Nothing loose.
Next is to check swing arm bushings.
Any other suggestions.
Thank you,
Roger
Thank you,
Roger
I would get it on a Dyno and check if it is motor, or the drive / wheels.
All you have done so far is "Shotgun" the problem. Yes replacing the motor mounts, shocks and rebalancing the tires are regular maintenance for a bike of that age and was worth the money.
Who did the motor mounts replacement? If the motor wasn't checked for alinement that could be a problem. If you have the manual you can do that yourself.
PS: been there and done that. Wish I had had followed my advice. Now I have a "NEW" 2005 Ultra.
KenK
KenK
Maybe unbalanced tire(s}. I once had an `09 Dyna. It had a little vibration at high speeds that I couldn`t figure out either, but it wasn`t bad enough to bother me and it didn`t show any problems. `Could be just the nature of that bike model.
