System comparison
04-22-2019, 10:50 PM
System comparison
Old system: harley 6.5, powerbass 800 x 2 running 4 polk mm652's. No line levelers. Sounded decent but I wanted more lol. So I just installed the sony axv 5000 and a stinger spx 700x4 running same polks. Hpf on on both front and rear. Gains at 2 o'clock position. Crossovers around 80. Sounds good but not any better than the old which is hard for me to believe. Could I be doing something wrong?
04-23-2019, 10:13 AM
2 o'clock does not say a whole lot when you have 2 different amps. Did you set the Gains on the new amp accordingly?
What head unit was pushing the powerbass?
Juice
04-23-2019, 10:36 AM
Stock harley head unit with the power bass.
04-23-2019, 10:59 AM
Set your gains on the new amp. There is a sticky at the top of the forum.
Let us know how it turns out.
Juice
04-23-2019, 01:55 PM
Are you using the Sony and the Stinger crossovers? Your post kind of sounds like it. If so you should only use one or the other.
04-23-2019, 02:13 PM
Did some more tuning for sure helped. Do you have to have your phone plugged into USB for android auto to work? Cant get mine to work with bluetooth
04-23-2019, 02:19 PM
No only using the crossovers on amp
04-23-2019, 09:31 PM
Android auto does not work via Bluetooth. You must plug your phone into USB #1.
04-23-2019, 10:04 PM
Quote:
Originally Posted by
eggwhite93
No disrespect eggwhite...This is not a true statement...i used my android auto on bluetooth with my sony 5000 today...
04-24-2019, 07:35 AM
bdrummer0413
None taken. I learn new stuff here every day. Thanks bdrummer!
