Any ideas where to put or place my dayton dsp?i got 14 limited sd 800 in fairing stock pods sd nano in there also need ideas ?maybe bt114 brackets ill take all info and pics please
I feel like someone told you this already, but the JM tray probably won't help you. The two amps you have jammed in the space by the pod won't fit with the JM tray. You need to cut those pods up and cram some **** in them to make room for your toaster!
At 4.55 inches I'm not sure if it would fit on a BT bracket or not, in your favor it is only an inch tall. Give them a shot if your done trying to make the pods work.
