Oil in the air cleaner?
Old 04-24-2019, 08:17 AM
JWaldron's Avatar
JWaldron
JWaldron is offline
1st Gear
Default Oil in the air cleaner?
I have a 2010 FLHTK. I recently upgraded the AC to a kuryaken. When I pulled off the stock AC I found a fair amount of oil had soaked the old filter. A couple of days after I changed it I opened it back up and again there was a film of oil inside. Can anyone help me understand why this might happen and what I should be doing about it? Thank you!
Old 04-24-2019, 08:41 AM
bustert's Avatar
bustert
bustert is offline
the hd breathes into the cleaner.
2010, the umbrella valves maybe getting hard.
high mileage?? then blowby beyond what the separator can handle.
design of the cleaner
some just pipe the vapor to the outside into a catch can. myself, vent directly into the carb throat.
Attachment 611098
Old 04-24-2019, 08:49 AM
JWaldron's Avatar
JWaldron
JWaldron is offline
1st Gear
It has 72K on it. That's creative, is that a kit? or did you come up with that? I saw one that had an external "oil seperator" looking filter plumbed down below the AC, was curious what the purpose was, makes sense now. Are the "umbrella valves" something one could change?Thanks for the response.
Old 04-24-2019, 09:10 AM
Tired's Avatar
Tired
Tired is offline
Received 4,453 Likes on 1,694 Posts
J, if you do a search on the forum for "oil in air filter" or something similar, you will get enough info and pics to keep you busy for quite some time. There are many ways and methods of dealing with it. Most, including myself, route the breather tubes to ground. Some claim relief by running the oil level lower than full. Others put a sanitary napkin below the filter. (no joke)
It's been an issue for many years. You could open the rocker boxes up and renew the umbrella's but that may not help. Some of that oil is getting ingested into the intake and crudding up the combustion chambers so you should be getting it away from there however you choose to do it.
JWaldron (04-25-2019)
Old 04-24-2019, 09:25 AM
Slowpoke62's Avatar
Slowpoke62
Slowpoke62 is offline
I went to the Vo2 Naked from V&H. the breather tubes vent directly into the throat of the air intake https://products.vanceandhines.com/store/harley/71028/
There are other methods too. One other thing you might want to do is replace the filters in your overhead where the tubes come from.
Old 04-29-2019, 09:13 PM
harkon's Avatar
harkon
harkon is offline
DK Customs has external breather options. I added a catch can kit from them, never regretted it.
Do yourself the favor.
darterd
Engine Mechanical Topics
18
10-02-2017 08:40 AM
68_340_Cuda
07-30-2013 08:04 PM
dave6511
Exhaust System Topics
09-23-2012 08:35 PM
Twinrider
03-10-2010 10:29 PM
SD Night Train
05-02-2009 06:30 AM
Quick Reply: Oil in the air cleaner?
