Heads upgraded
Heads upgraded
So I installed an HPI 51mm bore throttle body with 4.9 gps injectors with some FM Level B ported heads with some other toys. Runs great after some tuning. The front end lifts on every gear change under hard acceleration. I wasn't expecting the bit more of valve train noise though. I saw that DJL mentioned the improved valve springs can cause some more valve train noise. Have others found this to be true?
I have a very different engine than yours (88 up to 97, carbureted), but I've found the same thing. I'm running S&S 585s and have a lot of headwork, topped with stiff beehive springs (I have better specs somewhere in my notes). I've adjusted pushrods several times (I've tried preload from .125 to .145) and installed Rockout bushings. The top end is definitely noticeably louder than it was pre-build (although it wasn't stock then either).
After I had my heads done with high lift springs and bigger valves I did notice more valve train noise. The hammer is coming down harder! Loudest at 2500 rpm silent at 3000. Louder with synthetic oils. I hardly even notice it anymore. You will get used to it. Not crazy loud but noticeable.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
That is THE classic symptom of rocker shaft tapping. There is help
