Rear Sprocket Bolts Keep Loosening
Good morning everyone.
I am having an issue with my rear sprocket bolts on my 2006 Road King coming loose. I have tried loctite and it seems to not have helped. Anyone have this issue before? I have found a mechanical locking solution that will help. Just wanted to see if yall have any experience in this area.
You need to start over. Replace them with proper Harley fasteners. Check the fit of thread in the hub. Then put proper primer and red permanent grade Loctite. Torque properly. My guess is they are low quality chromed China fasteners or your hub is messed up. Usually, if they come loose, aluminum threads are damaged. It may be possible to save hub by studing it with grade 8 studs and use grade 8 nuts. Best probably to replace it all if damaged.
Received 47,744 Likes
The following 6 users liked this post by Uncle Larry:
Campy Roadie (05-20-2019),
Dan89FLSTC (05-15-2019),
hattitude (05-14-2019),
Lakerat (05-14-2019),
Neggy ZRXOA 5248 (05-14-2019),
and 1 others liked this post.
Not sure what I did before I bought my thread chaser kit many years ago, but it is the MOST used tool in my tool box these days...
There are many thread restorer (thread chaser) kits around, very similar to this one...
https://www.sears.com/craftsman-40-p...SABEgKgJPD_BwE
The following 2 users liked this post by hattitude:
Uncle Larry (05-14-2019)
