All of a sudden lost power... | 1999 FXR3
Old 05-18-2019, 10:19 AM
Stingray702's Avatar
Stingray702
Stingray702 is offline
Default All of a sudden lost power... | 1999 FXR3
I was riding home from the gym last night..Took off from a red light was going through the gears when all of a sudden the bike lost all power. It didn't shut off, but the gear wouldn't engage. Thought maybe it slipped, down shifter, the bike lurched and gear still wouldn't engage..Coasted to a stop, probably in the worst area as the next street was uphill around a blind curve, no sidewalk, and I just got done KILLING my legs in the gym.
Got the bike off the main road. Checked tension on the clutch, all good there. Went through the gears with the bike off, seemed everything was fine. Started the bike again, and something just didn't sound right. When I first hit the start button there was a short whiz. Once upon a time the screw holding in the jackshaft backed out and the starter made the same noise. Will pull the primary off today and get a better look. I'm hoping the chain tensioner didn't fail.
I swear this bike has ghosts...There's always something
Equipment:
- S&S 113 w/ 600 cam
- Baker 6 Spd Trans
- Baker Street performance 9 plate clutch 37T
- Thunderheader
Thanks for any and all help!
Old 05-18-2019, 01:14 PM
Stingray702
Look at the compensator. There was some nylon in there that looks like it came out.
Full on primary.
Prices of metal and nylon in fluid
Chunk of nylon bouncing around like a ping pong ball
Old 05-18-2019, 02:05 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,808 Likes on 3,313 Posts
Who makes that compensator?
Old 05-18-2019, 02:12 PM
Stingray702
I think it’s BDL. I got it from Drag Specialties.
Took the compensator apart
You can see where it started rubbing on the spacer.
The threads are ground down. Probably the metal shavings I saw in the fluid
More ruined threads.
Old 05-18-2019, 03:14 PM
98hotrodfatboy
Stick with the OEM... IT WILL NOT LET YOU DOWN LIKE THAT......
One would think the sprocket would be a reverse thread....
Old 05-18-2019, 03:34 PM
Stingray702
Probably gonna go back to that. Looking up parts right now
Old 05-19-2019, 06:17 AM
98glider's Avatar
98glider
98glider is offline
I wonder if it is still available? A lot of parts are n/a might have to go aftermarket
Old 05-19-2019, 06:38 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
Maybe someone here has a spare. Wouldn’t hurt to ask.
Old 05-19-2019, 06:43 AM
98hotrodfatboy
They are still available... Very expensive through the Dealer.. you can also get used or aftermarket new on Ebay... Book says it's a 25 tooth..
Old 05-19-2019, 11:46 AM
Stingray702
Stock was 25T comp with a 36T clutch. I went with 24T/37T when I up-graded the primary..I wanted a little more torque. I wish Baker made one, but it looks like they don't. My buddy is a tech at HD so he's gonna see what my options are
Quick Reply: All of a sudden lost power... | 1999 FXR3
