Leaking pushrod tubes
I brought my 2006 street bob for a primary bearing replacement, fluid changes, and to check the cam tensioner.
Received the bike back a couple days later with a leaking primary cover and my front header cracked due to poor reinstallation.
Brought it back a couple of days later to correct the issues.
Picked up the bike today and oil is leaking pretty badly out of my cam pushrod tubes. Is this in any way related to the repairs they did or is it just coincidental it happened on the way home? The shop I used comes highly recommended I don't want to be a tool with these guys but if it's something they did I want it repaired. I have 30k on this bike and have never had any problems before the last few weeks.
My primary was starting to make noise, it would go away if I was stopped and in gear. I took it to the shop to change my rear primary bearing. Service writer recommended I have my cam tensioner inspected. Told me it was 2 hours labor so I told him to do it. While it was in there I got all the fluids changed. When I picked up the bike they told me the tensioner was fine and in good shape and the bike was all set. On the way home I stopped for fuel and in the 5 minutes I was at the gas station I developed a good puddle under my primary. Took it home and found the bottom of the primary leaking badly. Took the bike back to the shop and they replaced the seal on my primary. When I picked it up the second time all seemed well. Got home from the shop and the whole right side of the motor, pipes and the inside of my leg we're covered in oil.
I don’t follow this....please explain. The top retaining clip wasn’t centered and that caused leaking ?
rear cylinder...the intake clip is centered but the exhaust is not.
I had both front clips off and it made a mess on a run to the Lone Star Rally and back...lost about a cup of oil.
So you ran it wout the retaining clips?
And is that a gap above the clip on right of pic near the head? And if so how did it stay on like that?
