Well $#it...I sumped this evening
Got hit by the sump fairy this evening. 2019 cvo, cam put in on May 31 and outstanding til this evening. On a back road I decided to run through the gears hard from a stop, ran it up to 5th and then just cruised, about 2 miles later pulled from a stop sign and it was very sluggish, not much power, I pulled over and checked the oil, just showed a little on the tip of the stick, let it sit for about 10 mins but it didnt seem any hotter than normal, was only about 2 miles from the house so I limped it home. Sucks *** but what cha gonna do. Guess my honeymoon phase is over, LoL
Eccool (06-21-2019)
All you can do now is pull the crank trigger out and drain the oil from the crankcase area. Put it back and fire the bike up and it should go back to normal running again. Sorry it happened but that's the normal time when they do it, run it hard and then shortly afterwards you have trouble.
Steve,
Can you explain the process of pulling the crank trigger, is it difficult?
Did the cam already void the warranty?
smitty901 (08-21-2019)
