PTT switch delete
Old 06-14-2019, 08:50 PM
3dognate's Avatar
3dognate
3dognate is offline
Default PTT switch delete
I've got a bad switch pack on my '17 RGS left controls, I'm switching the switch packs out for lighted ones. I have zero interest in the Push to Talk (PTT) switch. Anyone know if I can can just remove the switch from the PCB and use my existing plug? or is it not worth it to ditch a useless control?
Old 06-14-2019, 09:15 PM
batman.'s Avatar
batman.
batman. is offline
my 14 has the ptt button removed dealer said it was why my FM sucked so they took it out. FM still sucked so I got cm. button is still gone.
Batman
Old 06-15-2019, 01:26 AM
Bluehighways's Avatar
Bluehighways
Bluehighways is offline
It's a CAN Bus System on your bike.
If the computers on the CAN System (and there are a few) expect to see a switch that isn't there, they will probably not like it and you will not like it that they don't like it.
Much simpler and easier to leave it as is and just not use the switch.
Old 06-16-2019, 01:16 AM
Hammz's Avatar
Hammz
Hammz is offline
Batman
More likely the swapped for right side switchpack with someone that was adding a CB & they needed the PTT for that bike. PTT has absolutely nothing to do with FM reception.
Old 06-22-2019, 06:27 PM
Tjroadie's Avatar
Tjroadie
Tjroadie is offline
What's up with the left switch pac? Dealer wanted to replace mine, it wouldn't start in gear and would idle inconsistently. But the cruise worked! The neutral safety switch behind the clutch was sticking. Took it off and work some graphite in it's been fine for months now. Saved $250 for a little maintenance.
Old 06-23-2019, 08:19 AM
24v's Avatar
24v
24v is offline
I would think you could unplug the old switch pack and plug in the new one. As long as the issue is actually in the switches and not the pcb. The wiring is no different from there to the ecu. 2 wires for the can system and 2 wires for power/ground.
Old 06-23-2019, 10:55 PM
3dognate's Avatar
3dognate
3dognate is offline
I actually ended up not having a bad switch pack but instead had a buggy flash to my ECM. After flashing back to my original map and back to my custom tune, my stuff started working again and I was able to cancel my order for the lighted controls.
soulpatch
05-27-2019 01:14 AM
Thumper26
09-13-2016 08:42 AM
LKHA
12-29-2014 09:25 PM
Am4wag
07-01-2013 05:12 PM
28gauge
02-18-2009 03:04 PM
Quick Reply: PTT switch delete
