sporster battery goes dead in two days
Did you test the new batteries before putting it in. Try putting it on a battery tender and fully charge the battery first. No sense testing the battery if it is not fully charged. How do you know the battery is dead...did you put it on a meter or it just does not start?
more info is helpful...what kind of battery, what is the CCA, what do you have on the bike that may cause parasitic drain?
As a general guide.... Battery should be 12.6 or higher. Mine reads 13.2. When you turn on lights and start, it should go no lower than 9v. When it is running, it should read more than 14v when you increase rpm.
When I first got my Sportster I thought the battery wasn't holding its charge but then I realized that you have to hold the starter button down and wait for a second before anything happens. This is especially true when cold starting so maybe you don't have a problem at all . Try it .
No , I don't think so . I've seen quite a few reports that suggest that this is a perfectly normal characteristic of starting a Sportster . There are no loose connections on my bike . Thanks for your concern though .
