Wiring help seres or parrellel ?
Trying to understand all this before I blow something and I think I may have wired wrong already, current set up is stock head unit on a 2009 street glide pac loc stinger amp mmats 601 cx how should this be wired ? As I believe stock head unit is 2 ohm ? Right now I have it wired to front channels positive speakers to positive on amp , negative speakers to negative amp
thank you for any and all help
eggwhite93 (07-14-2019)
Technically....
We don't have enough information....IMO..
The fronts come in 4 or 8 ohm.
The stinger 700?
The Only way to sufficiently power the rears is in 3 channel mode with them wired in parallel to the 350x1 at 4 ohm. Otherwise they will be severely underpowered.
Amp is
175W at 2ohms.
125 at 4 ohms.
Should be(but no ratings) 75 at 8 ohms which is just enough for your fronts if they are 8 ohm.
Sorce
The stinger 700?
Amp is
175W at 2ohms.
125 at 4 ohms.
Sorce
Technically....
The stinger 700?
Amp is
175W at 2ohms.
125 at 4 ohms.
Sorce
The stinger 700?
Amp is
175W at 2ohms.
125 at 4 ohms.
Sorce
Sorce (07-14-2019)
