Accessory Wiring Harness ???
Dealer installed Elec Connection update kit P/N 69201599A on my 2018 Tri-glide before delivery. I suppose for XM, WHIM, Heated grips, ..etc.
I have now added ACC switches for the right side of the Fairing Dash and purchased AUX POWER SWITCH KIT-FAIRING MOUNT P/N 71400129 so I can add fans, and other things.
I have mounted the harness as per the instructions EXCEPT I don't know how to find the proper 925B connector to insert the bare lead in #3 hole, supplied with the fused cable that goes to the positive terminal on the battery. or where to plug in the the 925A supplied to the 925B.
So I am in over my head, ok. Wanting to learn. Anyone able to assist? Might be very simple for some and it may be staring me in the face??
New Switch box RH side, nothing connected yet.
Plug from 71400129 Kit, called 925A in the kit. Supposed to connect to 925B
Previous Update kit P/N 69201599A (the jungle) which may be hiding what I need.
Round end to positive bat. terminal, no problem. Bare end (square) to be inserted into 325B! I DO NOT KNOW WHICH IS THE PROPER 325B. How do I find it?
Not trying to be a smart *** here but spend the money on the Factory Service Manual and the Electrical manual, the parts manual is nice to have too.
The first two have told me everything I need to know about my bike.
Hopefully someone can give you a quick answer to your current question but those books would tell you in minutes w/o resorting to the net. And I'm sure this won't be your only question.
I think he's looking for connector 325.
If I'm reading this right:
The Dealer installed Harness used slot 3 on connector 325, the same slot your looking for on the second harness.
Harness installed by dealer
https://serviceinfo.harley-davidson....1?locale=en_US
2nd Harness
https://serviceinfo.harley-davidson....9?locale=en_US
2nd Harness
It is in reference to the fused wire that goes to the battery.
MAYBE what you are saying is, YOU DO NOT NEED THIS AS YOU HAVE THIS FOR OTHER KIT? IF SO I MAY BE DONE!
Right? Or ?? THANKS A LOT
2nd Harness
2nd Harness
This plug is used for the Cool Flow Fan but it has a Seal Pin in one slot. Could I remove that pin and insert the fused power wire terminal in there?
Maybe I do need the second fused wire for this harness just like the one for the first one? Does that make sense?
TIA
Connector 325 was used for the dealers added harness. You may be able to find a Y splitter to plug into 325 but you need to find out what electrical load the dealer added to the circuit and what additional load you will add with your circuit.
