Advice on lower fairing removal
Old Jul 22, 2022 | 09:56 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default Advice on lower fairing removal
I need to remove the left lower on my road glide limited for some paint work. Can the radiator and fan be removed from the fairing without being disconnected, was just thinking if the fasteners can be removed from the lower and then remove the lower away leaving all the lines still connected to the radiator. Can this be done?
Old Jul 22, 2022 | 10:09 PM
mjwebb's Avatar
mjwebb
best advice I can offer is 'don't drop it'
Old Jul 23, 2022 | 07:55 AM
scj's Avatar
scj
Don’t fret about removing the radiator, it’s easy to prime the system.
Put everything back together and turn the ignition on, hold the throttle half open and that’ll engage the water pump and fans. Top off the radiators then install radiator cap and turn off the ignition.
Old Jul 23, 2022 | 08:30 AM
00fxst's Avatar
00fxst
as long as it's the same as a 2014 you don't have to disconnect the radiator,the pics are from when i did the water pump.
Old Jul 23, 2022 | 08:40 AM
dontdropit's Avatar
dontdropit
Something like that is what I was thinking, only its the left side. Shouldn't be any different.
Old Jul 23, 2022 | 09:13 AM
00fxst's Avatar
00fxst
no different,i don't know if they fixed the nutserts on these things but if it spins take the grill off and use a small drill bit (i think i used a 1/16)and drill through the base of the nutsert and about a 1/16 into the plastic and the bit will hold it from spinning
Old Jul 23, 2022 | 11:15 AM
dontdropit's Avatar
dontdropit
I have heard of that problem, hopefully that's not happening now.
Old Aug 6, 2022 | 08:50 AM
dontdropit's Avatar
dontdropit
Well I got it replaced, no problem at all. Everything can be removed from around the radiator and fan assembly. And yes I had one nut insert that spun, so yes this is still something to be cautious about.
Old Aug 6, 2022 | 09:17 AM
scj's Avatar
scj
Thanks for the update
Old May 25, 2026 | 04:45 PM
Harleybabe2015's Avatar
Harleybabe2015
Stage I
Yes it still is. We have 2017 Tri Glide Ultra
Having a hard time getting lower left fairing off. The screw insert (not sure if that's what you call it) spins, and we cant get it off. Our fan quit engaging and coolant light came on so we were told to change the ECT. Any suggestions on getting that screw off.
