Want to do this to deal with my back pain. I have spinal stenosis and can't ride with feet forward anymore. If someone wants to go from mid controls to forward controls, I would like to do a swap. Save us both $$$$ dollars. I am working on a parts list, won't be a difficult swap. Any interest?
Mid controls are on. Found used parts for brake side. Bought the HD accessory kit for shift side (don't have to change inner/outer primary). Of course HD says all this won't fit on FLHCS, but I didn't have to modify anything. Works fine with stock exhaust. Frames all are the same on 2018 up Softail, all mounting points there. Stock forward controls with boards are available.
@wmprof , could you clarify a bit on the footpegs you chose, and how you chose them?
I'm a little confused and unclear on the various sizes, as it seems Harley has several different sized footpegs. Not sure how you pick the right ones for these mid-control kits. The instructions appear silent on the matter
I used the stock mid footpegs, not accessory ones. Those same footpegs are on my Pan America now since it uses same softail mounting.
