Small Oil Leak: 05 Deluxe
Purchased the bike 02/24 without a leak. Immediately I knew I wanted to change the cam tensioner pads and put 16" apes with assoicated cables. Completed both of those tanks. Sometime later I notice a relatively small drip of oil on the floor. If I were to somehow find myself with the bike in the air and directly over my head , this would close to the transmission drain plug area. The tranny drain is dry (I did not drain during new clutch cable). The cam chest seal is dry, motor oil drain plug dry (did drain during work and replaced the oring). The primary oil seal is dry. Closer inspection shows the drip coming off the left (if sitting on the bike) front of the shock under the bike. I can't im agine that's where this oil is coming from but maybe it is. Using a mirror and light, ive crawled all over this thing and cannot find the source. it's been a few weeks now and I feel I can rule out and type of spillage from the repair. Common sense says... no leaky.... I do work and have leaky..... it's something that ive touched but hell I can't find anything. Now the oil drip seems to be very consistent with the type of oil I topped off the primary, tranny and motor with, after the work was complete. Im at a loss here . Any ideas?
(On the bike) Left shock. drip on center and front
Tranny drain dry
Tranny drain dry
Tranny drain dry
Tranny drain dry
Also, check where the Stator wires go into the Primary case(front/left). There is a grommet there that gets hard over time and it leaks only when the engine is running. Mine started leaking within a week of buying it off the original owner. Instead of draining oil, & taking the primary cover off, and disconnecting the Stator wires to replace a 20cent grommet, I degreased it from the outside and slathered on Permatex Ultra gasket sealer. So far, no leaks in 8k miles.
In case you haven't fixed it yet.....
It's hard to tell in your pic, but that black mark could be a buggered up o-ring and that's why the trans plug is leaking...
You could luck out and just need an o-ring.
A dealer did that once to my trans oil plug o-ring, way back when I let them service my bikes.
