2011 FLHTK Rear Tire Change
Old Jun 3, 2026 | 07:27 PM
N1265's Avatar
N1265
Default 2011 FLHTK Rear Tire Change
Hi Guys,
I am debating pulling the rear tire off my 2011 ultra limited to have a new tire mounted, I have done this by myself on a motorcycle jack for the front tire without issue, but for the rear I would like some insight.
Most videos I see of people removing the rear tire on a jack are bikes without a fearing or lowers, seems like the ones doing a full dresser are doing it on a table. Is it safe to do this on a jack with a full dresser with the ABS system to deal with, or is it to sketchy. I am kinda worried if the bike will balance out ok on the jack with the rear wheel removed .
Any advice appreciated, the local dealership currently wants $800 ish to replace the tire and bearings, which is a little much for me right now.
Many Thanks.
Old Jun 4, 2026 | 03:33 AM
eighteight's Avatar
eighteight
Pull the exhaust and break the axle nut loose while still on the floor
Position the jack correctly and run a strap over the seat to the jack
You'll be fine
Old Jun 4, 2026 | 05:50 AM
Nokkon Wud's Avatar
Nokkon Wud
Tip it up on the kick stand.
Have someone slide a cinder block under it and stand it up.
Pull tire.
Have a beer.
LOL
Old Jun 4, 2026 | 07:32 AM
Hecklerboy's Avatar
Hecklerboy
I've done this with my Street Glide for years.
In fact, with my J&S Jack I haven't even had to strap it down.
Pulled both front and rear wheels, plus the front forks with no worries.
Throw a strap over it just to be safe.
Old Jun 4, 2026 | 08:03 AM
eighteight's Avatar
eighteight
Old Jun 4, 2026 | 11:25 AM
cwhite6's Avatar
cwhite6
If you are worried about it tilting forward, what I do (I am a belt and suspenders guy) is break the axle's nut loose while bike is on the ground, raise it a little to get the bike balanced on the stand, strap the bike to the lift, and then raise it to your working height. Turn the front to full lock on either side, and then put some blocks or something under the front tire. I usually raise it just enough above a locking position on the jack, put the blocks in place, and then lower it to the locking spot to put just a little bit of weight on the blocks. That way if you misjudged the COG, the bike will not want to tilt forward since the front is braced.
Old Jun 4, 2026 | 11:41 AM
EddieBlaize's Avatar
EddieBlaize
Some local shops will mount for free if you buy the tire from them. Still same price as off of the internet for the same tire.
Old Jun 4, 2026 | 08:12 PM
N1265's Avatar
N1265
Just got a quote for $480. at another HD dealer for tire and bearings (will mount for free like you said) but will also charge for wheel weights, the parts guy did not know what the final bill would be with the wheel weights but said it should be around $500. total with two weeks out to make an appointment. said it would take about 2 hrs.
The problem is it is for a HD tire, they said they would not get an American Elite which is what I want because I just put an American Elite on the front last year and I want to keep them the same. So I will go ahead and pull the tire and take it to an indy dealer.
Many Thanks
Old Jun 5, 2026 | 05:25 AM
Short Shift's Avatar
Short Shift
Pull tire.
Have a beer.
LOL
I've done that with a big rock on the side of the road a few times.
{But I did it one time with an aftermarket kick stand, and it broke. That was no fun.}
Old Jun 5, 2026 | 08:35 AM
Weeboy1's Avatar
Weeboy1
They will sometimes mount for free on a loose wheel. They won’t remove, mount and reinstall for free.
