Boombox GTS with WHIM
Old Jun 4, 2026 | 05:20 PM
LWoo's Avatar
LWoo
Default Boombox GTS with WHIM
I ride a 2022 Street Glide ST with a BoomBox GTS and a WHIM. I use a Shoei GT Air II with a Sena SRL MESH system. I had to reconnect my Sena system to the bike and now the connection Fails. It does the same thing with other Sena Systems indicating the issue is with the Harley. 2 different Sena systems Fail connecting to 1Harley. Has anyone experienced something like this?
Old Jun 5, 2026 | 07:41 PM
FurryOne's Avatar
FurryOne
A little history lesson - Years ago I was doing a tech page for the local Hog group, and I bought & tested the WHIM with my '17 SGS. What I found was that HD played games with the WHIM software. It's made by SENA under contract, and SENA made HD's comm gear until recently, so you'd think that generic SENA comms would play nice with the WHIM... it won't! You see, HD specified an AptX audio codec in their branded gear, while SENA uses an SBC audio codec in theirs. The AptX is better and more expensive, and while it's designed to fully support any SBC codec it finds, HD stuck in a software routine that switches to monaural if it doesn't see their AptX codec on the other end of the connection. So while SENA's branded gear "should" connect fine, well... The only way to get full control and stereo from older HDs is to ditch the WHIM and get a SENA FreeWire interface (requires HDs 7-pin accessory adapter). That allows you to get real stereo and full control functions, including CB (if you have the CB module & buttons installed). I was using the SENA 30S at the time. I also tested the Cardo PackTalk, which is another can of HD worms.
Old Jun 6, 2026 | 02:27 PM
cycle7447's Avatar
cycle7447
Community Influencer
Take a look at the J&M dongle - get rid of the WHIM and this will work perfectly. Plus, this will be in stereo with your headsets.
Old Jun 7, 2026 | 08:17 AM
asa1199's Avatar
asa1199
You can not have your phone connected to the Sena, only to your bike at the same time.
ghcustoms
Audio Systems
May 22, 2025 05:10 PM
Bartman37
Apr 30, 2021 11:29 AM
mountain man
Aug 15, 2010 08:15 AM
mtdrop
Apr 12, 2008 10:01 PM
2006streetglide
Oct 19, 2006 05:30 PM
