Adding topout spring
Old Jun 5, 2026 | 10:25 AM
Ghetto blaster's Avatar
Ghetto blaster
Default Adding topout spring
1988 FLHTC, wanting to lower the forks just a bit, going to add an additional topout spring (stock length) is my thinking correct, this would increase the current preload of the stock spring?
Old Jun 5, 2026 | 11:19 AM
Racepres's Avatar
Racepres
How Much Lower??
For 1" I cut the inch off the spring, and Put it under the Damper!!
Old Jun 5, 2026 | 11:40 AM
Schex's Avatar
Schex
Originally Posted by Racepres
How Much Lower??
Never thought of that, which end? The tight wound or the regular wound side?
Old Jun 5, 2026 | 12:17 PM
Ghetto blaster
How Much Lower??
Just the length of an extra topout spring, I'd guesstimate about 1.25 inches, my concern is how much it will change the preload of the forks (all stock)
Old Jun 6, 2026 | 07:52 AM
Racepres's Avatar
Racepres
Putting the cut-off part under the damper will Only change preload by the Kerf of yer Cut!!
I cut off the Looser end..for placement under Damper..Dont take much to eliminate "top-out" banging!!
Old Jun 6, 2026 | 09:27 AM
Max Headflow's Avatar
Max Headflow
I would not use part of the main spring for an additional top out spring. For 1 when you cut it, the cut side is not flat. It can **** and drag in the fork tube. You can get away with using a cut main by placing the cut side on fork cap side where it doesn't slide.
Old Jun 6, 2026 | 10:34 AM
Schex's Avatar
Schex
I have some 1" fork lowering spacers for the damper tubes I haven't used yet, don't remember where I got them.
Pro Action has some I see, don't think I paid near that much, hey Max can make you some.
https://street.pro-action.com/store#...it/p/304543172
Old Jun 7, 2026 | 08:02 AM
Racepres's Avatar
Racepres
If you dress tyhe cut end...I have personally Never had a Problem..
But, alone, they Increase Preload..has to... Sure are proud of their "spacers" tho...
Old Jun 7, 2026 | 10:29 AM
Schex's Avatar
Schex
Right, if you don't cut springs.
The old air ride springs are soft, might work out not cutting them and run less air, especially with the 1" less travel, that experiment could have that job being done twice though, the price you have to pay to know.
Is this a setscrew?, maybe to keep it in position for an oil hole? The ones I have don't have that, might be better than floating around even if there's no oil hole to cover.
Old Jun 7, 2026 | 11:34 AM
Racepres's Avatar
Racepres
Probably...But...I sure don't see "floating around" under preload!!
