Shameful story with a happy ending
Old Jun 5, 2026 | 02:51 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default Shameful story with a happy ending
As the title says this is a shameful rather embarrassing story but I share it because it may help someone else. I was working on finding top dead center on the rear cylinder of my 2023 ultra limited. I was using a plastic straw cut down to about 6 inches in length to see when the piston was at the top of the compression stroke. I left the straw in the cylinder and went around to the other side of the bike to check the lifters. I grabbed the rear wheel and gave it a little back and forth wiggle to look at the position of the lifters. I watched the lifters and then went ahead and rotated the engine a couple revolutions. Then I heard this cracking noise. Immediately I new the straw was in the cylinder. I took off the gas tank and removed the other spark plug. I was able to stick a pin light in that spark plug hole and in made plenty of light in the cylinder. I then went around to the other side and could look down into the spark plug hole and I could see the straw. I was able to stick a piece of wire into the end of the straw and guide it back into the spark plug hole as I rotated the engine. You can see the picture of the straw it must have got into one of the valves because it is pinched. Like I said shameful and embarrassing but it ended well. I consider myself very lucky. Maybe this will help someone else not make the same mistake.
Old Jun 5, 2026 | 02:54 PM
YZR's Avatar
YZR
You were lucky, go but a lottery ticket! 🍀
Old Jun 5, 2026 | 02:55 PM
MURPHCC1's Avatar
MURPHCC1
Good for you Sir!!!!
Its happened to many!!!
SOME have even forgot all about it!!!
Old Jun 5, 2026 | 03:46 PM
elPrez's Avatar
elPrez
Imagine the sound of a pencil snapping off. Yes I **** myself, had a panic attack and proceeded to make a one day job a two day job.
Was my son in laws bike. Yes he’s still my son in law and yes he brings it up every year on the anniversary of when I did it.
Old Jun 5, 2026 | 04:02 PM
squirrelsnest's Avatar
squirrelsnest
Nice job getting that straw out!
Old Jun 5, 2026 | 04:11 PM
Rains2much's Avatar
Rains2much
Why did you cut the straw short? If you leave the entire straw it can’t sink past the whole.
Old Jun 5, 2026 | 04:13 PM
470004's Avatar
470004
Glad to hear it worked out for you.
Old Jun 5, 2026 | 04:22 PM
dontdropit's Avatar
dontdropit
The whole length of the straw would hit the gas tank.
Old Jun 5, 2026 | 05:27 PM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Things happen - But, it's cool when it's a fixable screw up. No harm, no foul.
You need to add this one to the running list of mess ups we have going in the general section - I think I'm leading the most mess up's; I can use some help to even it out.
Old Jun 5, 2026 | 05:50 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
That is crazy
