I am looking for the 2026 fog light wiring kit for a ROAD GLIDE... The plan is to connect the wire to the bike by the radiator and then cut off the two HD ends and splice in my two Denali D2 lights... Problem is that HD part number 69203216 says it DOES NOT fit the 2026.... Has the connector under the bike changed between 25 and 26 ??? If anyone has hook up fog lights to a 2026 ROAD GLIDE please tell me what kit number you used.
I can't imagine them changing that plug. HD has been notorious over the years for having bad P&A fitment info on their site. I suggest reaching out to Tim's Stereo systems on FB or His website and asking Him. I'm sure He's sold plenty of his kits ( which is exactly what you're gonna do with a much cheaper HD harness) to people with '26 bikes.
I installed the new HD fog lights on my 2025 Street glide Ultra that came with the lower fairings. It could just be that sense the standard road glide doesn't come with the lowers the website will not let you order just the wiring kit. I can't image they changed the plug on the 26. As your probably aware the 26 RG limited comes standard with the fog lights. While at the dealership you might take a peak under the radiator and check for the plug.
This is the one I think for the bikes to use the HD lights in the lowers. It's much longer and has PnP ends on it for the HD fog lights. Instructions for the HD Fogs mention needed this harness to plug into the port under the radiator but does not give the part number in the instructions for those lights. Go figure. https://www.harley-davidson.com/us/e...ess/p/69203622
install instructions https://serviceinfo.harley-davidson....hideTree=false
Both ends look the same where it plugs in underneath. I'm kinda shocked they're both the same price as the second one is substantially longer.
Chalk it up to HDs webmaster being behind again.
At this point I'd go to your dealer and see if they have both in stock to compare the plugs. If they're the same, buy whichever one suits your needs best.
