2011 FLHP different tune than civilian bikes?
Is it possible that Harley is sneaking a different tune on the Police bikes? The reason I ask is that my new leftover 2011 Road King Police (103 w/oil cooler) doesn't seem to have the issues that so many complain of, namely excessive heat and pinging under hard acceleration at low revs. I can't MAKE the thing detonate even lugging very low revs, it just pulls clean and smooth. I only get 35 MPG but that's at 80- 85 mph on the open road. I don't feel that this bike runs any hotter on the rider than my 1996 FLT, so what gives?
Thanks! :-)
Thanks! :-)
AFAIK H-D stopped with secret sauce pursuit motors after the Evo motor...what i was told is that the Twin Cam PD motors tended to be the top 10% within tolerances...*
Motorcycles are usually used for parade or traffic and spend much time idling. and because of this, low compression or de-tuned motors were often in cop bikes ( I started on cop shovels in the mid 70's).
There were high po pursuit motors available in the evo FXRP's with ignition module, police cam -(like an EV3) and milled heads .060" to raise compression to 9.6:1.
But the thing that worked in the bikes favor was the light weight.
i rode PD evo FLHS' and they seemed to not have the same motor power--- but that could have been the extra 250 pounds
specs from PD's ( like the CHP where mine came from in 1990) detailed acceleration rates, braking distance lean angle etc.
The published top speed was 104 MPH in 4th gear, with terminal speed unknown due to wind resistance ... however mine has been over 135 a few times...stripped down and weighing less ( no fairing or bags) and a 15% overdrive with the 61T rear pulley and softail belt.
Being a "gov't owned vehicle" it was exempt from emission controls at time of manufacture- no evap canister for example and the above mentioned cam and ignition.
I don't really think my 09 runs any hotter than my evos when it's 100º + out
Mike
* 2 sources; the first a technician in the motor rebuild program at Capitol Drive, and confirmed by Clyde Fessler
Mike
I have searched and am under the impression that the main difference is the tune. I believe its mainly timing. The reason I say this is, when looking at V&H fuel pak tunes. They list different tunes for touring 103's and police 103's. Now another difference I have noticed is a lot of gear whine in 1st and 5th gears.
Chris
Chris
I have a 2010 FLHP 103/w/oil cooler etc - LOVE IT! That thing is a monster! She pulls hard and just goes! I did an FM stage 1 with new headers to rid the cats and used the Power Vision. No pings, rattles, or effort - I let that clutch out with BARELY any throttle and she just leaves. Best 2nd purchase of an HD I have every made! Lots a good guys and info on those things here on this forum: www.retiredpolicebikes.com
Tell them I sent cha. ;-)
that's an interesting thought; anyone know if the 2011 FLHP is "cat- less"? I imagine it's there but it would be cool to know for sure before I change anything in the future.
I can tell you that the owner's manual for my 2010 FLHP specifies the use of 91 octane gasoline. It is the Police version manual.
