loctite on compensator
Old 05-25-2013, 02:45 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,481 Likes on 1,540 Posts
Default loctite on compensator
took brothers 2012 street apart due to stripped primary drain plug and found blue loctite on compensator bolt. thought this was suppose to have red on it? anyone else ever seen this?
Old 05-25-2013, 03:29 PM
CGLTD's Avatar
CGLTD
CGLTD is offline
Red as per manual for my '05.
Old 05-25-2013, 03:40 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
I use red...had one back out once on the 88...my fault.
wasted some fluid and a gasket.
did it right the 2nd time.
Mike
Old 05-25-2013, 03:44 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
The compensator bolt does not have red loctite, at least not from the factory, on any I have taken apart. The clutch hub nut on the other hand, does use red loctite. You can use red loctite on the comp bolt but if you plan to take it off again later you may have some difficulty. The blue has worked fine for me.
Old 05-25-2013, 03:45 PM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
Yes, red is what is recommended. The brand new nut I installed last year from Harley had white loctite on it. From experience, the white is the baddest stuff on the planet.
Old 05-25-2013, 05:23 PM
Leftcoaster's Avatar
Leftcoaster
Leftcoaster is offline
It all turns white after it's been on there awhile no matter what color it started out as.
Blue on the compensator bolt will work fine.
Old 05-25-2013, 05:26 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,519 Likes on 3,048 Posts
Yep blue is enough if torqued correctly.
EDIT: Service Bulletin M-1170 recommends 2 drops Loctite 262 ( That's the Red stuff.)
Guess I just learned something! But mine is a 2000 and with the hot forged crank in that model, my air impact gun has probably kept things tight regardless!
Old 05-25-2013, 05:37 PM
Joe2010ultra's Avatar
Joe2010ultra
Joe2010ultra is offline
I vote red also.
Old 05-25-2013, 05:47 PM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
I used blue 20k miles ago and torqued correctly. Works fine no issues.
Old 05-25-2013, 06:01 PM
Leftcoaster
Quite correct.
But the Service Manual also says to put thread dope on your drain plugs even though there's an o-ring.
Neither are necessary.
I've been using blue too, sans air impact - never had one come loose until I wanted it off.
Quick Reply: loctite on compensator
