What choice won't require new cables?
Old Apr 18, 2007 | 11:31 PM
Softtail Bob's Avatar
Softtail Bob
Default What choice won't require new cables?
I really would like to clean up the wires on my handlebars but don't want to have to buy new throttle cables, clutch cable, and brake line. I like the short apes and I like the drag bars but want to be comfortable without leaning forward when I ride. Anyone have experience with changing out the bars on their Fatboy without replacing cables? I have the 4" risers on right now with the stock cables but really want something internally wired.
Old Apr 19, 2007 | 12:27 AM
cleanimages's Avatar
cleanimages
Default RE: What choice won't require new cables?
i think 10 inch...
Old Apr 19, 2007 | 01:24 AM
Softtail Bob
That's the direction I was leaning. I was looking at the 10" mini apes in the HD catalog and from the looks of the measurements I think they would work. Anyone have personal experience with these bars?
Old Apr 19, 2007 | 06:39 AM
kmm's Avatar
kmm
I have an 06 Fatty
Changed the bars out to Hertiage bars
Same cables, wires etc.
Only thing you have to do is put a different bend in the Hydraulic brake line
Bars are 56 beans from the stealer and new grips are another 50
Bikes looks better and feels even better best move I did so far
The stock fatty bars suck
Old Apr 19, 2007 | 08:17 AM
forvols's Avatar
forvols
I just switched over to the chubby 10" mini-apes. Huge difference over stock bars(06-FLSTI), handling, comfort, looks all improved. Had internal wiring done also added braided cables. I would recommend chubbys over HD bars. HD bars will require riser change due to thinkness. The chubbys are necked down at the riser so you can use stock or replacement you already have that fit the stock bars. Saves alittle money. I had an indy shop do it along with adding accessory lights at the time. I purchased the parts.
Tony
Old Apr 19, 2007 | 08:18 AM
lionsqrne's Avatar
lionsqrne
Bob,
I don't have a fatty, but I have put the mini apes on my bike which is a standard. I ran the wiring up thru the bars except for the clutch and throttle lines. I did not have to change any lines out. I did not however use my original risers. Because the bars are 1 1/4 all around I used the risers off of an 07 wide glide. I wanted them anyway as they look nicer and are beefier. I believe they are a two inch riser.
I have no complaints about the seating position or the bars position. No back pains. The bars keep my hands at a perfect position and get no shoulder pains. I was worried recently when I put the new C&C sport and tour seat on which lowers me 1 1/4 inch that I would notice a difference but I didn't. Still comfortable.
I think they are a good choice as with the riser the 1 1/4 inch looks good all around. Nice beefy bar. I really would like taller apes myself but I want them in 1 1/4 now. I have been spoiled.
apetterez
Jan 21, 2015 04:35 PM
2lane69
Apr 4, 2012 04:53 PM
DynaRyda06
Jul 29, 2010 01:47 AM
UNCCHarley
May 14, 2007 11:52 PM
bensonjv
Feb 28, 2007 02:04 PM
