Vance n Hines quiet baffles?
The solution....I have an 07 Heritage, Stage One with V&H Long Shots. Pretty loud pipes, good throttle response but still loud and annoying crackle and pop on decel. Plus, in 2nd, 3rd, and 4th gears around 2800 to 3200 RPM, the V&H just hammer your ears with intense mid range, pop corn popper sound. My solution...I installed V&H Quiet Baffles, (a misnomer because they barely drop the volume, 2-3 Db per V&H). They do lower the exhaust note to a bit lower tone, which helps. But I was looking for more help, can't take the hammering mid range tone or the crackle and popping of the typical of "dealer installed" reflash of the ECU. So, I added home made lollipops. 2 inch bracket with 1 inch washers. Attached them through the end cap mounting holes (used longer bolts). Result ? Even lower exhaust tone, minimal, exhaust scavenging crackle and pop, and best of all, less mid range pop corn popper hammer your ears tones. At cruising speeds, the bike is very quiet on accel, still has some grunt, on decel, just a nice little burble, reduced the crackle and pop a bunch. Bike still has plenty of punch going through the gears cracked wide open but WAY more pleasant and less fatiguing to ride. So, get yourself some V&H Quiet Baffles and then go to Home Depot and buy what you need to make lollipops ($ 5.00). You will love the result
