Cam and big bore
I have a 05 heritage with se intake thunder header 2into1 I am thinking about s&s 510 cam and 97 s&s big bore heads will come later thoughts and suggestions please
When you do the heads, you'll probably want a different cam that matches better. I'd also find a shop that can bore your current cylinders to 98" and match it up with flat top Pistons vs buying a kit and hoping all the parts fit perfectly. Going the bore route lets you give the machinist the Pistons and rings to get it perfect.
Thanks for the info
<p>Scott at Hillside is a good resource. Give him your requirements and riding style and he'll set you up with a custom piston/jug kit to fit what you want. He won't try to sell anything you don't want. Great guy to work with.</p>
© 2024 MH Sub I, LLC dba Internet Brands
