Heat from the oil tank
I am considering purchasing a Softail vs a Dyna. My only concern is that the Softail has the oil tank under the seat and near the right leg when riding.
The Dyna has a battery at that location. How much heat does the rider get from the oil tank when riding and is there something that can mitigate the heat from that source? I like the fact that the Softail has a counter balanced engine and is solidly mounted to the frame.
We make a product called a Crotch Cooler and you install it under the seat so that you do not burn your self on the oil tank and cap. We have sold thousands to Softail owners for this very reason.. If you like just do a search on Captain Itch Crotch Coolers , If we can answer any questions just let us know. Thank you Larry .. http://shop.captain-itch.com/Crotch-...hields_c58.htm
It's actually a trade off for the better. It is quite soothing to hemorrhoids as it heat soaks the bottom side of the seat. Get leather. Willie and Max makes a heat pad plumbed to the tank. If you look close, you can see mine. It has a winter and summer position. So, it's really not too warm in the summer.
I never felt the heat from the oil tank but from the engine and my wife complained about the heat on her right leg even more. We went with the Capt'n Itch crotch cooler to deflect the heat from the engine and the oil cooler down and away from the rear passengers legs and my wife loves it. Hope this helps.
