Drive ratio upgrade HOW TO: Belt Pulleys, Primary sprockets, improve TQ up to 13%
#991
Hi, I've been reading this thread and wondered if someone might help me understand what cam is optimal for a 30 / 70 setup.
Current Bike Specs
2017 CVO Breakout
117 Kit
SE High Volume Oil Pump
259E cam
Stock 110 Heads
Bassani Pro Street Turnouts 2-2
My question is this, with an altered drive ratio say 30/70 is a cam that performs better higher in the RPM range more desirable? The current 259E comes on at about 3500 RPMS, assuming I'll get to 3500 very quickly with the altered ratio, do you want a cam that comes on strong early.
I want low end off the line TQ, just didn't know if moving to a lower end TQ cam would be that much better, or defeat the purpose somewhat.
I'm wanting to change my 259E and just want to make sure the change is compatible with the ratio change.
Thanks in advance guys.
Current Bike Specs
2017 CVO Breakout
117 Kit
259E cam
Stock 110 Heads
After doing the 30/70 swap, I found that what I achieved. And I'm sure the rest have also, was an over abundance of low end torque than stock.
Stop to stop in and around town cruising is ok.
But in a WOT off the line launch, I found that 1st gear was almost gone to where I'd redline too quick,
I've learned to switch into 2nd sooner which is also pretty short. In fact, not until after stretching out 4th gear... Can you then settle down before you're in 6th while tucked. But by then you're in the 113-120mph range depending. Which by then you way past that 1/4mi strip LOL
But what I'm really saying is that I can't understand why after doing this swap, one might want more from underneath?
Now if you had said... Is there a seven gear transmission option that would be optimal after doing a 30/70 gear ratio swap?, then I would be there right along side you in line.
Only I already asked this and found that S&S actually does offer one. LOL
#992
Received 1,934 Likes
Current Bike Specs
2017 CVO Breakout
117 Kit
259E cam
Stock 110 Heads
Current Bike Specs
2017 CVO Breakout
117 Kit
259E cam
Stock 110 Heads
#993
If you're "on the cam" at 3500 rpm, that won't change. What will change is that, with a given twist of the throttle, you'll arrive at 3500 rpm sooner than you did before the swap and have more rear wheel torque throughout the entire rpm range owing to the new sprocket ratio(s). You'll up-shift sooner and "top out" sooner but that will happen at pretty high speeds if you're in 6th gear and it won't be cam dependent. I can't see the point in increasing ratios to increase operating rpm's then installing a cam which optimizes low rpm performance. A cam that comes on soon, if thats what you want, would make sense so long as it delivers right up to the top of the rpm range too.
#994
Doing a cam without first doing the exhaust and intake is wasting the cam, as with a stock exhaust and intake, the cam can't really perform to its potential.
And yes, a higher rpm and the gearing change complement each other. My Stage 4 kit (original 2014 one, not the watered down newer one) plus the gearing change, has proven to be a dynamite combination.
Jim G
#995
I'm in the opposite side of this.
This is where I got a bit confused, I want more low end, and was about to jerk the 259E out for a cam with better low end, but I'm thinking that might be the wrong decision considering the low end issue should be take care of by the 30/70 ratio swap.
#996
#997
Agree. In fact, doing the 2 into 1 exhaust and betetr air cleaner should be the FIRST or 2nd thing done, with the gearing change being the other!
Jim G
Jim G
#999
