Has anyone ever used WD40 on the rear axle bolt, softail 2001 manual states to use anti-seize, talked with mechanic and he said to wipe it down good and use WD40 instead of anti-seize lubricant. The only time I've ever used anti-seize was on threads.
I give the axles a good coating of waterproof grease to prevent corrosion that would make extracting them through the bearings very difficult.
They typically corrode in the dead space in the tube that separates the two bearings.
