Heritage Valve Adjustment
It appears the pushrod tubes and pushrods would stay in place, but everything above the head including the rocker arms have to come off to get to that gasket. That includes the dash and gas tank.. I'd sure like to know what is on the dealer's mind as far as valve train noise after reassembly. Like I said, it should be a simple torque pattern and it's done. There shouldn't be any worry about noise, but I must be missing something since they said that..
ah sorry, I meant as in why would that gasket decide to leak? does something need to be checked to make sure it doesn't do it again?
and I don't see what they are on about either, the only new noise would be if you forgot to tighten something up and/or it worked loose?!!
A little update. I said I had a couple of rallies to go to and I went to one this weekend. Got home an hour ago as a matter of fact. The guy I usually ride with rides like he's behing chased by a hit squad. I ran just under 600 miles, most of which was between 75-80. The thing didn't leak a drop and is clean as a whistle. So, I don't know what to think.
This is just a wild **** guess, but I had a thread going on excess crankcase pressure and I commented that the guy I was trying to help (same guy I rode with this weekend) had developed a rocker box leak. I wonder if maybe I may have developed an issue with that myself and the hard running caused one or both of my crankcase vent valves (not sure of the official term) to free up. It's a few weeks before the next rally, so I'll have time for slower riding and time to see if it starts leaking again.
Does anyone know how to adjust the valve lash on a 2007 Heritage or if they are adjustable at all? I need to get a lower rocker box gasket replaced and the dealer said you don't adjust the valves. It is done by correctly torquing the rocker box bolts and that if engine is noisy afterward "I've" got problems. That sounded a little hinky to me so I thought I'd ask you folks...
If there is a noise and all is assembled correctly, you have a problem. Correct.
He could have said, if there is an noise after all is assembled correctly, there is a problem. Same meaning.
What is the problem here, there is no valvetrain noise, correct?
Get the gasket replaced and move on.
You don`t adjust the valves. Correct.
I haven't a clue why a dealership would make a ridiculous comment like that, not to mention that it's worrisome from a bike owners point of view..
webscrounger
Exhaust System Topics
06-08-2007 05:41 PM
