Dead 1985 softail
Old Apr 7, 2017 | 09:51 AM
Greeners's Avatar
Greeners
Stage I
Default Dead 1985 softail
Just bought 1985 softail fitted new battery, when ignition is turned on no dash lights just clicking from under the seat bike is completely dead. Main breaker maybe??????
Old Apr 7, 2017 | 12:22 PM
langwilliams's Avatar
langwilliams
you can try the evo section too....I'd check the ground cable then pull the dash cover around the ignition switch an check the wiring under there for broken/loose wires.
Old Apr 7, 2017 | 05:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Just clicking....
Does it click all the time when the ignition switch is on, or just when you push a button or switch???
Old Apr 7, 2017 | 11:43 PM
Prot's Avatar
Prot
There is a sticky in the Evo section about this problem...,,
https://www.hdforums.com/forum/showt...=845084&page=1
Old Apr 8, 2017 | 04:46 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The second relay trick doesn`t apply to some bikes, such as Softails, because the starter relay gets it`s power directly from the main circuit breaker.
Waiting to see if the OP is still around........
Old Apr 12, 2017 | 01:40 PM
Uncle G.'s Avatar
Uncle G.
Not really enough info to go on. Is the "clicking" continuous, or just once when the starter button is pressed? If the former, most likely you have a dead short somewhere and the main breaker is cycling on/off. If the latter, see the sticky in the Evo section under "dreaded click".
VA_Larry
Nov 12, 2022 03:41 PM
Truknoris
18
Oct 15, 2018 07:39 PM
cjw_doc
Electrical/Lighting/Alarm
Aug 15, 2018 06:41 PM
rickydog
May 13, 2013 08:35 PM
streetg7
Dec 19, 2009 01:01 PM
