16" apes on slim S clutch and brake line
Sorry I posted this in tech forums as well but I am getting desperate. I already have my bike apart!
Has anyone put 16" apes on a Slim S? I'm having trouble finding the clutch and upper brake lines. I even went to harley and the part #s for their 16" ape kit are wrong. I got a too short clutch and a lower front brake line. I'm thinkin I need a 44" upper front brake line and a 72" clutch line. Bike has ABS and hydraulic clutch. Thanks.
Will be doing this same thing soon. Man, really the best (only) way to get the RIGHT lengths is to wire up the bars and install them, use a tailors tape to measure exactly the lengths you want based on the routing that YOU want to use. Taking others advice could cost you in this department. Ask me how I know, lol. I’ve done several sets of Apes, and this method is the only good way.
Thanks Brother, I have also installed several sets of Apes and I know what Lengths I need. I'm just having trouble finding the lines. especially the upper brake line. I'm going to go try a local shop that makes them. I just doubt it because of the fitting on the bottom of upper line that connects to the abs. Thanks for the advice though you are absolutely right.
I just went to their site and it was kinda hard to find the adapter, so here's a link...
https://www.magnumshielding.com/Brak...es/absadaptors
Brake line can be found searching by make and model.
pigfoot63 (04-14-2017)
Magnum sells a full kit that comes with the brake and clutch lines and the wire extensions. I had an issue with the turn signal extensions on mine as Harley changed the type of terminals that go into the plugs at some point but I notified them about that over a year ago so they have most likely updated their kits for that by now.
