Talking myself out of externally venting air cleaner
I followed the suggestions of a poster in the forum when I started getting a little drippage from my A/C.
In the unlikely event I ever make a warranty visit to a dealer, it converts back to stock in about a minute.
Legality? I've heard it said that more reveneur's and EPA cops come into these hills than ever make it out again.
Exactly. My setup is the same and it would take 5 minutes to return to stock. My 'seat of the pants' dyno says that the engine is happier sucking in 100% pure air.
Just for grins I called one of the best known performance shops and asked them about the vent issue. They said if the air cleaner was one of the Harley air cleaners and if the bike was stock there was not much reason to vent it externally. Cams and higher compression as well as some after market air cleaners they recommended venting it externally. They also said they had never seen any unusual carbon build up with the internal vents on stage 1 bikes. Also mentioned that if you run the he'll out of it all the time you might consider it. But for normal riders with stock Or stage 1 bike doesn't really matter. Hope this is useful.
Unless you NEVER get on it, you will get oil out of the breather bolts. Even keeping oil level on the low side.
Now why would you want that spewing back into the intake?
It makes no difference if the air cleaner is a "stock" air cleaner or if there is high compression or not. A 96' motor is high compression to me. There is always higher and lower.
Do you HAVE to do it? Of course not.. but it's a certainly better than not doing it. I know I don't want that spewing back into my engine.
Oil will still get through the filter and really there is no benefit to doing it this way.. just get it out of there.
Similar problem, I have a 17 FLSTC stock, and whenever I run it hard, say 78 to 80 mph for half an hour I get oil dripping out of the air cleaner. Some spitting on my rear header pipe. Oil level is at the halfway mark on the dipstick hot. It's by no means wore out and im pretty sure it's broke in with 4,500 miles on it.
This is my 1st Harley, so I don't know if this "normal". Its not enough to make me have to add oil between changes, just enough to be annoying.
Is this too hard of a run for it?
HD dino oil changed every 2,500 miles.
I used to ride my sportster like a stunt man and that stock A/C would be an oily mess lol
I installed the DK Customs Stage 3 Anodized Black Breather Bolts on Reaper, so her engine is externally vented. When I first did the mod, I was getting quite a lot of oil misting, so I replaced the head breathers, and drilled the oil return holes in the rocker support plate to 0.0100". Now, I only get a super tiny bit of oil mist from the rear cylinder - only after along highway run at 75 mph, and the front is absolutely dry.
I'm very happy that the oil and hot air are no longer being fed back into her engine.
Cheers!
Cheers!
DK Custom - ST (09-20-2017)
