FYI. 2018. 114 oil change caution
I just changed my oil and filter. It was changed after a ride so it was hot. Manual says to put in 4 quarts initial fill. 4 quarts was barely above the add mark cold. So I added 12 more ounces to get it roughly half way on the dip stick cold. Went for a short ride and when I got home I checked it hot. The level was just above the add mark. Added 12 more oz and went for another ride. Checked it hot and it was 1/2 way on the dip stick. Bottom line if you just put in 4 quarts and ride it you will be below the add mark. I suggest 4 1/2 quarts before you ride it. I am at 4 3/4 to get it half way on the dip stick
The following 2 users liked this post by martin10:
Felix 808 (09-24-2018),
Søren Rix Petersen (09-14-2017)
Mine took just shy of 5 qts.
Found this info on the 2017 models. 4-1/2 quarts capacity.
2017 Milwaukee-Eight Engine Specs:
Engine: 107″ / 114″ / TC 103 rubber mount
Cylinder angle: 45 degree / 45 degree / 45 degree
Bore: 3.937″ / 4.01″ / 3.875″
Stroke: 4.375″ / 4.5″ / 4.374″
Compression: 10:1 10.5:1 9.7:1
Valvetrain: Four valves per cylinder / Two valve per cylinder
Ignition: Four plug four coil / Two plug one coil
Torque: 114 ft-lb. @ 3250 / 124 ft-lb. @ 3250 / 104.7 ft-lb. @ 3250
Starter: 1.6 kw / 1.6 kw / 1.2 kw
Charging system: 24-25 amps / 24-25 amps / 17 amps
Fuel system: ESPFI ESPFI ESPFI
Oil capacity: 4.5 quarts / 4.5 quarts / 4 quarts
Idle speed: 850 rpm / 850 rpm / 1050 rpm
2018 Softail models (Fatboy for sure) 5 qts.
Fuel Capacity 5 gal. (18.9 l)
Oil capacity 5 qt. (4.7 l)
Weight, As Shipped 671 lb. (304 kg)
Weight, In Running Order 699 lb. (317 kg)
http://www.ironsteedhd.com/PrintInve...14--id-3891548
